Anyone know what thier doing, and want to put a timing belt on for me? as well as set my ignition timing, kinda teach me to do it as well? I dont want to bend any valves, and im scrred to do it myself even with the FSM lawl.
It was done 30000kms ago supposedly. Thats what the sticker says. The belt is still very snug, not a lot of play, it still has the same torque as the fsm states for belt tension
I would suggest doing whether or not it still feels tight, you have the cover off and its a great learning experience. Aswell if you arent 100% (supposedly) that it was 30k ago and dont have any service records to prove it, I would go ahead and do it if you feel comfortable. Unfortunately, Im up in Fort Crack and cant help much.
Then again thats my opinion. Its up to you, if the torque/tension specs are good and you arent getting any rough driving issues, then right on.
Well the car is fresh off the boat, only driven from stoney plain to clareview lol. and then parked until now, the water pump is leaking so im swapping that out on saturday. I’ll be winter driving it, and swapping to an rb25 in the spring, so i dont really want to sink ANY money into the 20, if its gunna go, i hope it holds until spring. I only drive it here and there, not a DD so i should be ok.
Best way to check if you did everything right is is to turn the engine over by hand slowly, feeling for resistance. Stick a socketwrench on the crank bolt and turn it over twice (on that engine I believe). After the second revolution line the crank up at TDC and see if the rest of the markings still line up. If they do you’re gravy.
As to setting the ignition timing I have no first-hand knowledge. I just make a mark with a marker on the cover and CAS before I take the CAS off. :lol:
