Hello just put a new timing belt in the CA and i have a winding sound… Wondering if this is norm… Does the belt just need some time to break in? Thanks.
Sound has still not gone away… Any ideas?
your timing may be off on the belt
Your tensioner and idler pully’s spun freely???
They both spun free… Do you think i over tightend the belt? I dont think the timing is off…
there is supposed to be a small amount of slack in the belt, it should say in the shop manual (you push down between the two cam gears on the belt and it should be X mm of sag).
