Ok, so I happend into what is supposidly a Tomei Limit over system (L.O.S) Model 2000, its ur typical black box with tomei sticker on it,
no TM or R markings on it
It looks identical to to the Greddy speed cut remover accept it has
- Black (ground)
- Red (power)
- Yellow (?)
- Greed (?)
Problem 1:
It came off a R32 RB26DETT harness and im unable to find a referance to it anywhere online, as well there are no markings on it to indicate anything and im not sure if it is a universal one or ment for the RB26 motor only?
Problem 2:
Baring problem 1, I can safely assume that the yellow and green wire are to split the speedo wire. but if it is hooked up incorrectly what is my worst case senario? could i fry the speed sensor or the ecu?
I will try and post a pic of it up as as soon as i can.
Thanks.
