All of these parts came off my Silvia Race car and need a new home.
I need to sell these asap to fund my new build for 2014
all prices are very low for quick sale.
Don’t embarrass your self by low balling me… ill just ignore you.
S14 SR20 Mishimoto with mishimoto fans and shroud - SOLD
24x12x3" Greddy core intercooler with custom end tanks, 3" and 2.5" rated at 500whp - $200
25x12x3.5" Vibrant core intercooler with custom end tanks using 3" and 2.5" vibrant Van jen clamps rated at 800whp - SOLD
Custom top mount Turbo kit. Using only the best of everything! Precision 5858 ball bearing turbo, Precision 46mm Wastegate, AST top mount manifold with extra bracing, AST custom 3" down pipe, AN Oil feed and return, Ceramic coating on everything.
This setup made 603whp and 470 tq at 28psi on a Sr22 with 264 cams. - SOLD -
Enkei Rpf1 2x 18x9.5 +15 2x 18x10.5 +15 powder coated white. small chips in powder coat shown in pictures. NO TIRES - SOLD
Enkei RPF1 4x 18x10.5 +15. 3 are black 1 is sliver. in very good condition. NO TIRES - SOLD
Greddy Sr20 rwd oil pan - SOLD
rwd sr20 starter - SOLD
BNIB AEM Tru Boost - SOLD
Custom Bolt on Rwd Sr20 electric water pump kit. comes with everything you need to bolt this on to a s13 with a sr20. comes with 2 belts. (STOP OVERHEATING! If you rev past 5500rpm you NEED this)(can see up to a 10hp increase too) - SOLD
SR20det 7 layer SS exhaust manifold gasket (re usable forever as long as it is clean) - $40
Rwd Sr20 s13 Cylinder head. Ported ALOT, oil galleries tapped, new guides and seals, 90mm combustion champer, 1/2" head stud clearanced. ( You want to make big power without going vvl? this is what you need) - $250
Mazworx 90mm bore 1.1mm metal head gasket with 1/2" studs(still in excellent condition, only used for 3 hours) - $70
1/2" head studs for a SR20det ( block, head and headgasket will require modifications)( needed past 25psi) - $75
Custom S13 RHD Oil catch car that fits behind the passenger strut tower. - SOLD
Rwd sr20 CAS - $50
S13 black top valve cover MINT - $40
Custom S13.4 Sr20 valve cover with x2 -10 AN fittings - SOLD
S13 coupe rear roof wing - SOLD
S13/S14 Rwd SR20 pulleys with good s14 water pump - SOLD
White line S13 front adjustable 27mm sway bar - $175
