So I recently purchased an HKS Turbo Timer Type-0 and I’ve run into an odd problem.
I have every wire connected (thanks to Adam) and soldered and wrapped. +12V Constant, +12V Ignition, +12V Accesory, E-Brake wire, RPM signal wire, Ground.
The Turbo Timer does all the features it’s supposed to except for one thing: It doesn’t do it’s job. When I turn the car off, the car turns off, it doesn’t idle like it’s supposed to. The turbo timer isn’t doing what it’s supposed to do. When I turn the key to off, the timer starts counting down but the car is turned off.
I don’t get it.
