2007 Raptor 700
770
+5 Hot Rods Crank
105 cylinder
105 14:1 CP Piston
RE +2 CNC Head
Web 4 Cam
54mm White Knuckle TB
FCI Intake Tube w/K&N Filter
Sparks XX6 2.5" Exhaust
Plug Wire Mod
Power Commander 5
Dynatek Ignition w/DL700’s curves
Slingshot Clutch
PCV Valve
Laeger +2 A-Arms
YFZ front shocks
revalved stock rear resi shock
GForce Adjustable Axle
Maier White Carbon Fiber Plastics
Kosta Electronics Pan
Laegers Anti-Vibe Stem
Jet Trim Seat Cover
ASV F3 Clutch and Brake Levers
Streamline Clutch Cable
Galfer Front and Rear Brake Lines
Galfer Rear Rotor
UPP Case Saver
ProArmor Fat Peg Nerf Bars
ProArmor Tether
TM Design Chainslider
Should be around 380 LBS
Made 80HP on the dyno.
Right now it needs to be ran on striaght C112. $230 for a new piston and you can run 93. It will have trail tires not flat track stuff as its already sold.
$4500
