There isnt really a tips section anymore so i put it in here.
I just did an oil change and decided to fill up the oil to just the bottom of the low line and OMG the difference it made was huge.
Throttle responce and acceleration was unbeliveable!
I was skeptical when people were telling me this but its true i noticed a difference and so did my friend who i said nothing too just took him for a boot and hes like what did you do? The car responds quicker.
Damn… this may be the cause of my loss of power after the oil change!!
When I first got my engine working, the tires used to break lose as soon as I hit 4000 rpm in first gear (from a rolling start)… After I got the oil change, I checked the level and I overfilled by a little, but never though anything of it.
Since the oil change, the tires hasn’t smoke in first gear since. I never knew this is possible. I always thought it might have been something else I did… hmm
The KA has the worst crank windage of any engine I’ve experienced. Quite literally the difference between my oil at the top hash or bottom has was either keeping up with SiRs or losing to an Si.
how much of a honest differene will that actually make, i mean if you were to put the car on a dino. i can not see have a litle more oil making the difference between loosing to a si and beating a sir
It’s the opposite of my VQ35DE.
When my oil is low I loose power.
Unfortunately my engine started burning oil at like 47,000km due to those stupid pre-cats breaking down and getting sucked back into my engine… so whenever the oil was down below the hatch my car would feel like a DOG… when the oil was topped up it suddenly felt spritely again.
(i’ve got a new engine now, hooray warranty)
Diesels spin slow but run hot. Our engines spin fast and run cooler.
If diesel oil was so good for our engines, wouldn’t Nissan and every other car manufacturer be recommending we use that? After all, if it makes the engine last longer and run better, wouldn’t we be using it already so that manufacturers could brag about better reliability and performance?
wouldnt’ you want to fill up your oil in the winter… because when they put it in it’s at about 20degrees… and when your outside it’s - 30 that means alot less oil
