Before I go throwing parts at this is there a way to test to see which one it is without a scan tool? When I got this car last november it had the same problem and the guy who fixed it said he could get the solenoid to click with his scanner, so its probably not that? Pretty sure he put some grease on the gas cap so it would seal.
BUT, recently I had the car parked for a week and a mouse managed to get in the engine bay and chew up a few wires. I have since repaired them, but there is a chance I didnt see one, which may be causing this too…
Had the same DTC on my 1999 Accord it was the EVAP control canister vent shut valve. If you google “p1457 accord” you will get tons of information on it.
yea I did that a few weeks ago, and got tons of info. lol. I am just wondering if anyone has any tips to diagnose without a scanner.
I should be able to find the relay then provide power or ground to get the solenoid to click over. Ill have to find the wiring diagram to see which the ecm controls.
Is there any way to check the valve without a fogger?
the soleniod is $46 and the valve is $62 through rockauto.com.
thats what I was thinking. when I got the car last year they did the grease around the gas cap trick to get it to pass, so I was thinking it could be that, but its the wrong code…
bump, I got a new gas cap last fall, seal is in good condition.
inspection is due november and I REALLY dont want to pay someone to diagnose this, but I’m afraid I might have to get someone with a techII or the like and a fogger…
bump. can anyone fix this for me? I am willing to pay, but I feel if i go to any random shop its like walking in with a blank check. It has to be on a weekend, and my inspection is up in november. So there isnt a rush, but I need to get it taken care of asap
have u pulled out the vent solenoid and applied p/g to it to see if it works properly? thats one of the most simple things you could do in this situtation cuz purge valves go to shit all the time! i know first hand nissan and dodge have huge problems with their evap systems so i wouldnt doubt this is where your problem is.
