So I’m in the process of designing a blog and found a template that I really liked as it was a 3 column design, but it’s pretty plain. I’ve been playing around with changing the colors of the template and finally found the string that changes the background color globally (wouldn’t let me do it through the editor).
I changed it from light gray to black, but now all of the corners of the page elements are light gray and look ugly. I’m looking to either change the color to black, or remove them completely but can’t seem to find the code to do so.
I found this site http://wigflip.com/cornershop/ which will generate code to give the page elements round corners, but I can’t seem to find the section of code that it’s looking to replace. If I just paste it in, it doesn’t generate any errors, but it doesn’t change anything.
can anyone give me a hand with this? This is for a blogger blog BTW which I hear is a little different from standard web design?
NO! NO! NO! NO! NO! NO!N O! ON! using images is lame! you should be able to code the whole thing WITHOUT images. other than a logo or what not… WITH OUT images!
He said he found a template and started making changes to it. I assumed that meant he was using the template and making changes to it. That would mean he just wants to change the current rounded corners, not code his own.
