I have a flange that i need to weld to my hotpipe, so i wanted to know if anyone here can weld professionally.
PM is key.
Thanks.
PM is key.
Thanks.
Hi…
is there anyone in toronto area that can do this? or does any one know any shops that can?
P.S i forgot to add the hotpipe will need to get a cutout for the flange.
SG can
its not hard to weld a flange onto a hotpipe … for a bov im guessing? any exhaust shop can do it.
unless its aluminium in which case id take it to a fabrication shop.
It is aluminum.
PM S13Counterpart, If you want quality work and will accept nothing less than perfect. ESPECIALLY when it comes to TIG welding, I’ve seen robots that don’t weld that clean.
I would if i could, but he’s from barrie and I dont have a car since mine is stored which is why I need someone local in toronto area.
lol my bad, best of luck to you!
there are a lot of shops in the gta that can do it. i’d start with the affiliates listed here. pur can probably do it.
if you can’t find anyone, i can do it. you can see some of my work here: www.weirtech.ca/gallery
No they can’t. I don’t work there anymore ![]()
Go see DOBA. He’s an old time SON member. Has his own machine shop near the Airport.
He can weld aluminum no problem Made my custom intake and all my IC piping
http://www.herculesmachine.com/.
Jeff
