I’m looking for a welding supply store. The liner in my welder that the wire feeds through is jammed with wire and I cannot get it out so it needs to be replaced. What are some decent welding supply stores and how much does the liner run? thanks
rodger’s welding supply
1791 Fillmore
Buffalo, NY 14214
716-893-3636
Fax: 716-893-0090
^^thanks :tup:
no problem, they are EXTREMELY helpful
Buffalo welding is in tonawanda right by the GI bridge, Strate is in North Buffalo right by Delta Sonic, and Praxair formally Mills welding is in North Buffalo right by bagel jays.
Sheridan Rd exit right that says BUFFALO WELDING SUPPLY CO right when you get off the 190
thanks i’ll check them out :tup:
