Well, After pulling the quickest build from scratch in history, and running into a number of absolute BULLSHIT fuck-ups along the way in getting ready to build it (only to be topped off by a slew of last minute fuck-ups as well), its running, and together. Driving… well, thats another story as of this moment. Trying to get the car together for VOI9, which I have now missed, I ran through a number of let-downs and mistakes on the part of my suppliers that killed my chances. Some of these things, like being sent Low-Impedance injectors rather than Peak and Hold injectors, 2 driver side hood hinges misbagged as one of each, and a flywheel that is just plain too light even though it is “claimed” to work fine, my chances of making it in time were squashed. (and beofre someone calls it, yes, P&H injectors are low impedance too, but 2.4 ohms VS 4.8 on a P&H Driver is a BIG difference in response time)
Right now, everything is ironed out other than the tuning and flywheel weight issue. Unfortunately, I am 8-12 weeks out for a custom flywheel from Tilton. I figure I will use the time between now and then to ATTEMPT to get the car running with the excessively light flywheel, as if I can pull that off, it should run like a dream with a heavier, more streetable flywheel. On a side note, the reaon the flywheel wont work is that it was designed on a Comp Coupe using a Motec engine management system, and the street PCM cant respond quick enough when at idle speeds to make the car driveable on the street- I was not informed of this fact until a few days ago. Thanks Tilton…
When putting it together, i revised many of the attributes of the engine and its parts, and added back many of the things that other tuners have removed because of the difficulty in adapting them to work with aftermarket components.
Incomplete list of mods to the engine:
-2006 block
-fully studded with ARP-2000 studs
-Billet 4340 Caps w/custom machining to allow crank scraper to be reattached
-Custom Carrillo Rods with FPO
-Custom CP Pistons
-Custom Cam
-custom adjustable timing set for Gen-3 Engine
-Modified Comp Coupe Oiling System to eliminate its design flaws
-Full Floating .990 pins
-Full Coating Set
-Clevite H-Series Triarmor Bearings
-Custom Axle-less composite roller lifters
-Double-Keyed ATI Damper
-Fully Hand Ported heads to maximum flow… done by the “Best” in the Viper world
-Ferrea Super Alloy Valves
-Titanium Retainers
-Super-7 Billet Locks
-Isky Springs
-Cometic Gaskets
-Jesel Mohawk Rockers
-Ported, Extrude-Honed, and Powdercoated Manifold and T-Body
-Custom P&H Fuel System capable of 1500HP @ Static 55 PSI Rail, or 2000HP w/Boost Referencing
-Tilton 3-Plate Carbon/Carbon Clutch, Flywheel and HRB
-Custom Urethane Engine Mounts with Internal Locks
-Custom EMS with selectable input logging
Getting there slowly but surely… accomplished a LOT over the last 4 weeks, with a lot more to come this winter.
Atleast come springtime you know youll be ready to roll once you get the few last lingering issues resolved. :tup: Im gonna buy you a giant beer once its all done and then steal your keys when youre wasted :tup:
