STEP BY STEP TIMING ON SR20DET…?
do it like this step by step
1 turn car off disconnect tps
2 REV it up to 2500
3 ?
4 ?
5 ?
thanks
2 REV it up to 2500
3 ?
4 ?
5 ?
thanks
for real nobody …?
read the fsm
---------- Post added at 10:15 AM ---------- Previous post was at 10:15 AM ----------
are you talking about the timing chain?
…i dont think he would be reving it up to 2500rpm well doing the timing chain he wants to know how to adjust his CAS i believe
ohh
thats in the fsm to!!! reaad!
gandza your a dumb ass but thanks
first off is your timing off? check first with a timing light
im pretty sure u have to start at top dead center its been awhile so im not positive
remove valve cover line up cas dots its tricky when putting it back in but doable u kinda have to put it alittle to the left and when putting it back it will go in the grooves and line up nice then put cover back on and bust out a timing light it has to be a 15 degrees witch is the 2nd line on the left on the crank pully so when the light flashes that mark will be there but again this is a basic description on how to do this and there is prob write ups everywhere like nico so this is basicly the procedure but look it up first hope this helps like i said its been awhile did it like 3-4 years ago but if ur timing is off a bit when done your car will run smooth
Yea frankduxx i pulled the valve off and everything is lined up i checked that last week its all ok . i have the same problem i did the timing years ago now, i forgot how to do it right again . what i mean is with the CAS, i think some one said to disconnect the tps but from there i forget…? thanks
no leave the tps where it is
