My 180 came with a small battery but it’s dead and the fmic setup doesn’t allow me to fit a regular sized one.
Does anyone know where I can buy one in Edmonton? or does anyone have one forsale? Need it asap
Thanks 8)
Thanks 8)
go to canadian tire and buy the biggest one for a lawn mower. i have used on for 2 months now and it is perfect. I think it is 59.99 were as the miata one is 135 ish. the only problem is that you will need to modify the posts because the lawn mower ones come with a top mount bolt style only.
My electric fan runs when the engine is off and i have yet to drain it.
how many apms is the battery? and do you have trouble starting in the winter time?
i found a motorcycle battery at partsource, 280 crank, 245 cold crank. is this any good?
noooo the canadian tire equivilent is 500 CCA ish. or that is what mine has right now. it is 20 dollars more and should work jsut fine
sounds good, thanks for the help
I have a perfectly good small JDM battery here, I only removed it because I already had an Optima battery. Let me know if you want it, it needs a good home
