hey i jsut got a a catback exhaust for a 13 hatch and was wondering if it will fit on a 13 coupe?
much help is appreciated
I am going to go with Yes,
why wouldn’t it? :roll:
It will sit about an inch more in… the coupes are slightly longer in the back.
when purchasing an exhaust they only specify s13 or s14 so i would assume there was no diff for s13 hatch/coupe
so that means i’m going to have trouble putting in
No, it will be fine.
pavels old exhaust is hanging from my hatch np. The pipes stick out a touch more. You will be fine.
Andrew.
all the mounting points are identical, you cna even use an R32 catback if you want.
the only problem is that hatchbacks are ghey where as coupes are the REAL DEALLLLLLLLLLLLLLLZ
