Will the Ka power steering pump work on a red top Sr20? If so does anyone have one for sale? I’m trying to find a Sr20 one but am having no luck. I was told a Ka one would work if you use the old brackets. Any information would be helpfull. Thanks.
Yes the KA one will work, as long as you re-use your old brackets.
I was probably the guy who told you this at Mills today
Thanks, I just wanted to confirm.
Never knew that some parts are interchangeable,hope everything should work accordingly whether it is a fix of a mod.
Accessory Belt Tension Pulley/Power Steering Pump/Automatic Transmission Filter/
Heater Hose/Horn Button/Idler Arm Repair Kit/Ignition Module/
Intake Manifold Gasket/MAP Sensor/Mirror Switch/
