willwood hydraulic e-brake fitting issue
So I have a Willwood cylinder here and the two fittings for it are 7/16-20and a 3/8-24 for the other end. I seem to be having trouble finding an adapteror something that will fit with my stock hard brake lines (s13). I hear a 1/4is very similar to a 7/16-20 and I could probably get one to fit my brake line,but I remember trying something like this a while back and thinking 1/4 was abit loose, I can’t quite remember. Anyway, has any one dealt with this, andhave a solution on where to buy the fitting and which one to get? Thanks.
http://www.brakequip.com/ ?
you may not want to fit the hydro ebrake to your stock lines, if that line blows or any brake line blows you will lose all ability to stop. Best way is to add another caliper that is dedicated just to the ebrake. Unless you still have the cable ebrake attached, then you have a secondary way of stopping.
