Wood Burning Insert
wood burning insert. $350 pick up only
http://img.photobucket.com/albums/v77/layzie298/3E83K43ld5La5E85K5cce3227594d1cc2116c_zps7e84df57.jpg
http://img.photobucket.com/albums/v77/layzie298/3L33Jd3H65Ld5K15M7cce80fbe469d9ae1962_zpsca48593a.jpg
this also can be nice to heat a garage
I may be interested based on a few things:
Manufacturer and model?
Exterior and Interior sizes?
Location, size and direction of flue?
Does it have a fan?
Where are you located?
What size logs will this take? at least 18"?
Has a fan never turned it on tho, it will take 18" logs. It’s full cast iron with fire brick and the flue is located on top. It’s 30x23x28 and the motor is 6" off the side. Interior is 22wx19L. This is very heavy
---------- Post added at 10:46 AM ---------- Previous post was at 10:45 AM ----------
It’s located in tonawanda and have a fork lift to be able to lift it in a truck
bump
