Woot, work on the 240 has started - engine is out w/ pics
[quote=“01AudiS4,post:17,topic:30619"”]
^You my friend must know very little about putting power to the ground. HRK is doing the right thing.
[/quote]
LOL!!! Ok and you do? driving a Audi? Are you KIDDING me right know
I just got done reinstalling a 04 Cobra IRS in my GT after throwing that piece of shit Solid axle in the dumpster. If I keep the car it will make serious power. It is being built for 800+ since day 1. The IRS will hold that with ease and hook, and corner, and be comfy.
I would like to see what a chassis without the reinforced lower control arm pickups (240sx) for a solid axle will do when you launch it with some torque/slicks. Mustangs that were BUILT with a solid axle in mind tend to rip the reinforced torque boxes out… I am interested to see what that 240 will do… since I know nothing about putting power down.
[quote=“HotRodKid,post:20,topic:30619"”]
well this isnt a cobra IRS in this car
its not posi
its got shit grearing
its the weak center section
all the bushings are beat
the struts are beat
you guys are right, i should spend 2k+ fixing and upgrading the rear suspension, instead of spending a few hundred to install the posi /3.73 ford 8.8 which only has like 400 miles on it
[/quote]
I hope you build some very thick lower suspension pickup points and spread the load out over solid chassis section … keeping in mind the direction of the loading
use a panhard bar.
Dont use the upper control arm pickup points on the solid… geometry is a joke
3 link
woblink
30 feet of square tubing laying in the garage for the frame already
10+ feet of round tubing laying in the garage for the suspension
k, sounds good.
Why did you choose a 240
becuase it was $600 and it doesnt weigh much
it was originaly supposed to be a driver, but the engine turned out to be on the way out when i bought it, so if i gotta swap it i might as well have some fun in the process
You dont want to do a SR or RB swap and go nuts?
I figured the price was right. :slight_smile:
Just consider how much weight this extra steel and parts will add… and what the swaps will cost you versus getting a Fox body or something already setup for what you want.
What motor are you thinking?
it will definately be a fun ride when its done.
http://www.sonikempire.com/gallery/albums/userpics/10007/IMG_3765.JPG
only his is a 3.0 not a 3.2 like the one pictured (same block and crank but different bore and rods.)
the basic car isnt worth doing a sr or rb swap to, if i did that id want to get the thing spotlessly clean
im using an engine i got for free, 3.0 yamaha out of a taurus sho. and im going to boost the fuck out of it (intercooled and meth injected)
hope my turbo is big enough
http://inlinethumb10.webshots.com/5129/2656427160035029491S600x600Q85.jpg
http://inlinethumb45.webshots.com/5420/2279763650035029491S600x600Q85.jpg
lol, you always come up with the wacky projects…
but then again my dumb ass is no one to talk :smiley:
[quote=“Violator,post:30,topic:30619"”]
[/quote]
Ha, if your ass could talk…
That’s a pretty cool project HRK. Did you make a completion date for yourself, or are you just going with the flow until it’s completed?
About time, been waiting awhile for this to get underway.
[quote=“Pass McGrass,post:31,topic:30619"”]
[/quote]
going with the flow. i have things i ACTUALY have to pay for this summer, so this is just a “whenever i can oford shit” type deal
subframe is off, tomorrow ill liberate the transmission from the block
wiring harness was removed and put away till later, that will need a load of mods’
http://inlinethumb05.webshots.com/3588/2412231600035029491S600x600Q85.jpg
http://inlinethumb30.webshots.com/4381/2906763310035029491S600x600Q85.jpg
http://inlinethumb60.webshots.com/5947/2527564400035029491S600x600Q85.jpg
edit: and oh yea, looks like my custom bellhousing might also have an integrated midplate for mounting the engine. might have to build the front section of my roll cage early so i can mount the engine thru the fireall to that
Dooo it!
Man that engine needs a good cleaning, and I still see an A/C compressor on that. :stuck_out_tongue:
Holy shit! In this thread I can see into the future! :eek:
Looks good man. :headbang:
the wiring needed on the chassis side of things is simple, this is a tibit from a ka24e-to-ka24de swap write up:
Wiring:
  1. Locate the body harness (under dash harness that attached to the ECU) that attached to your old harness. Cut the old connector off (the one that attached to your SOHC harness) and attach your DOHC body harness connector. Just match the colors!
    Yellow/Red --Tach
    Yellow/Green–Speedometer
    Orange–Ignition start
    Black—Ground
    Blue/Black—Water temp sensor
There will be some wires left over. These are for the SOHC’s diagnostic plug, and are unnecessary
so after i hook up the needed items out of that list …and figure out something for the tach and speedo … all i have to do is take care of any extra wiring the sho ECU needs
simple :slight_smile:
so this is what all the tubing is going towards. at least it is going to a good cause. :tup: looks like a fun project. always welcome to bring your shit to work if you need it welded or whatever
the engine and tranny are laying in the driveway :slight_smile:
next stop is a quicky dangle of the v6 in the engine bay so i can mark the firewall for clearancing, and check some fitment stuff
then ill gut the front suspension,replace the framerails,do a temp reinstall of the suspension and see whats next
http://inlinethumb53.webshots.com/5300/2988078700035029491S600x600Q85.jpg
http://inlinethumb36.webshots.com/6819/2957016510035029491S600x600Q85.jpg
