basically my 240sx convertible has windshield damage, it would be easiest to just get a new frame instead of fixing the one i have, Im looking for any frame off a 240sx, hatch & coupes work fine, as i will have to do some custom stuff anyway, the cheaper the better. Also would like some1’s used or damaged front windshield just need 1 to use as a template for the frame specs,i have had these offered to me free for damaged 1’s, hopefully some1 can help me out, thks alot Sunjay, call me if you have something asap 416 843 4682
BUMP
bump
bump
ive got a car im parting out, the glass is minty too! no cracks… let me know
how much
$40
coupes, convertibles , and hatchbacks all use the same glass?
yup! i dont see why it would be different
this guy needs a window frame and a windshield…bro call me im sure we can work something out! brand new windshield is 185 installed and we can figure out something about the frame… the windshield is a huge structural part of youre vehicle!! lmk bro
so your sellin one for $185? and im sellin one for $40…
bump
To clarify - are you looking for a vert windshield frame or a non vert one --the glass is the same but the frame is not. The vert frame is reinforced in a number of critical areas so if you are intending to replace a broken vert windshield frame you should replace it with an identical one. Maybe you can clarify what you are trying to accomplish.
i need a windshield frame off any normal 240sx 89-93 even vert, if not i’ll take a normal 1 and do some modding, im guna run a cage to reinforce the normal windshield if i got that routee also, the top frame of my vert frame is not bent much so i could probably weld it on to the sides of a normal windshield frame, thks let me knw, Sunjay
my buddies got a parts car in oshawa, he’ll give it to you cheap. You can text or call 289-688-6447 to get ahold of him
will do, thks bro
bump, found something maybe, just getting an update if any1 has anything though
Yea man, I still have it , if your still down, Just bring what you need to cut what ever you want. Again 289 688 6447, for any parts you need.
yeh sorry bro been real busy at work, i’ll probably been down for this weekend coming
Well let me know cause i need the car out of my garage, the 180’s going to be going into hibernation
