WTB: High output Rad Fan For SR20DET Rad.
Im looking for a high output rad fan for my SR20DET koyo rad. I want something with a adjustable tepmarature switch. If anyone has one for sell or can get a kick ass deal on a new one let me know, thanks.
nothing works better than the factory fan shroud for ducting.
i have one, if you want it pm me
c’est faux
http://home.satx.rr.com/nissanweb/RadTest/RadTest.htm
go with statistically supported data, not forum fodder.
The stock SR mechanical fan and shroud is NOT on par with the Flex-A-Lites and Altima fans but is does an acceptable job of cooling.
yep, I’d go with twin fans from an altima or stanze if I had to do it again.
$10 from any scrappers…
may need slight trimming (of plastic), to match rad size of S13 but will not need to be trimmed into the fan area
Im using twin altima fans and they work amazing. You will have to trim the shroud a little to make it fit tho.
