i know this is a little vague… but i dont really know what to post. my friend hydrolocked his 99 civic ex last night. he needs a motor asap. post up what you have… thanks.
since he has to do a swap, he shuld just put a B16 in it…
edit: best bet is going to be Honda-Tech.comHonda-Acura.net
i have a full b18 swap. it should work with his car…minus a few mounts.
i was asking $1100, but ill take $900.
b18b
ls tranny
axles
mounts (for 92-95)
shift linkage
bag of wiring harnesses
distributor
spare b18a head
needs head gasket, timing belt, and a 3rd gear synrcho
http://www.nyspeed.com/forums/showthread.php?t=15203
if you do not want to click
snip
It is ST00K motor and was rebuilt from pan to valve cover. everything was put togather with OEM honda parts. BUT the valve springs are skunk2 http://www.skunk2.com/Merchant2/mer…Product_Count=4. Was dynoed @ 130 last year. Has about 200 miles on it. will make a great low boost motor or DD
the machine work alone cost $650… and the assembly from machine shop was $250 and $240 for the springs… NEED TO GET $700
Ill take the old motor for free if he dosent want it. I will also pick it up.
so pulling the plugs and trying to pump the water out didn’t work, eh?
what a sucky way to end an evening.
i got my 1.5 motor out of my 91 civic now sure on miles but runs like a champ, no knocks or ticking from lifters
prolly going to part it so lmk
well if its a 99 then its obd2 and he should really just start calling junkyards. otherwise all the harnesses will have to be swapped out and such.
