I might be buying an auto SR20det. Wondering if anyone can help me get the needed parts for the swap? I will know in 2-3 days if I need these for sure, or if the sale falls through.
Please let me know if you have any or all of these.
clutch and brake pedals
clutch cylinder and lines
clutch
flywheel
driveshaft
and ECU.
and any other parts i might be forgetting.
thanks
I have a S14 SR20DET flywheel and i have a slave cylinder.
sweet thanks, I’ll know soon if I need it and will let you know.
i have a tranny if you need.
I have the tranny, just need everything else!
i would be worried about the clutch hard line, pedal assembly and the interior pieces you will need. I suggest you find somebody parting out a 180sx or a silvia.
agreed, I am looking!
the pedals should be the same on a 240sx, does anyone know if any of the other parts cross over to USDM?
Are you just swapping auto - 5spd in a 180 or silvia? or bought an auto engine set to put in a 240?
if your doing an auto-5spd swap in a jdm car:
The clutch pedal is a straight swap usdm-jdm. you will need to use a jdm brake pedal or just cut the side off your auto pedal to clear the clutch. (copy the size from a regular 5spd pedal and zip cut it to shape, all done!) The usdm clutch hard line will not work on the rhd car its way to long. an auto repair shop should be able to make a new hard line to anylenght you need using the ends off a usdm clutch line. just be careful when bending it that it doesn’t kink. Clutch cylinders are dirt cheap at an auto parts store, when ever you do a swap go pick up a new slave cylinder there around $15-20 depending if you have a discount.
that’s some great info thanks! Please share any more you might have.
i have the tranny brace, a drive shaft no sure what its for, stock clutch
