As the title says just wondering if anyone has a P72 they would like to trade for my P28 plus ill throw in some cash. If not does anyone have a aftermarket intake manifold for a GSR? Im either going to chip the P28 and disable the secondaries with a aftermarket IM or if keep stock IM on a chipped P72.
Thanks as always guys :blue:
              If I understand you, you’re trying to either get an ecu that can control the iab’s, or get rid of them with a different IM?
You can control those iab with a chipped P28 after you add some extra hardware and run the p72 codebase, it just won’t be able to have a knock sensor.  Otherwise aren’t the IAB’s normally open if you don’t hook up the vac lines?
Just throwing that out there.  I have a chipped P06 modded to p28 I can add the IAB control if you want.
