hey guys, i purchased a xentec hid kit for my 01 honda civic not too long ago and after installing it doesnt work corectly. the driver side turns on bright and then starts flickering then turns off. the passenger side flickers but has never turned off. not sure what to do, maybe the ballast is junk, maybe a relay setup would fix it but not sure how to wire it. not enough voltage? any suggestions? thanks
[ame=“http://www.amazon.com/Computer-Warning-Canceller-Anti-Flicker/dp/B002O95M3K”]Amazon.com: HID Kit Computer Warning Canceller & Anti Flicker (1 Pair): Automotive[/ame]
i had the same problem with HIDs I purchaed from Xenonlink.com. They worked fine for about a year but eventually started doing what you described. Ended up putting the stock lights back in but considering buying a better set of HIDs.
Btw, nice looking Civic, love the wheels.
