your thoughts on wheel adapters?
so ive been on the hunt for a new set of wheels since I bought my truck.
I loathe all the options ive seen in the 5x5 bolt pattern and last night I kind of had an epiphany, now im wondering if I can make these z06 wheels work…
http://i.ebayimg.com/00/s/NDkwWDUwMA==/z/QMAAAOSwq7JUDb20/$_35.JPG?set_id=2
I obviously understand that I would need a 5x5 --> 5x4.75 adapter and I found some that are 2" thick which would help take care of some of the backspacing issues that I would have.
specs on these 2001-2004 Z06 wheels are:
Front:
Wheel size: 17 x 9.5
Offset: +54mm
Tire Size: 265/40/17
Back Spacing: 7.38” (187.35mm)
Rear:
Wheel size: 18 x 10.5
Offset: +58mm
Tire Size: 295/35/18
Back Spacing: 8.03” (204.05mm)
so if I were to find a 2" set of adapters that would make the front 17x9.5 with a 5.38" backspace and the rear an 18x10.5 with a 6.03" backspace…I would also be using 255/50-17 tires up front and 275/55-18 tires in the rear
my current setup is
front:
18x8
4.5" backspace
255/45/18
rear:
18x9.5
5.25" backspace
295/55/18
although I did just stumble on this guy running the same wheels as me with a more aggressive front setup
http://67-72chevytrucks.com/vboard/showthread.php?t=700692
18x9.5 with 5.25" bs on all 4 corners
so it seems like the front wheels would work no problem but the rears I may run into some issues with.
my real question is should I feel comfortable running 2" adapters ?!?!?
z06 wheels :frowning:
really?
I think they would look pretty good.
im just so fed up with the lame flat lip lots of dish options and I don’t really love rallye wheels enough to run them
Those are one step away from this
https://www.kauffmantire.net/prodimg/american-racing-hot-rod-torq-thrust-m-chrome-large.png
THATS WHAT I DONT WANT TO RUN.
and to be fair I have not seen ANY c10’s running c5 z06 wheels…and im on the internet… A LOT
Tough gig…
I support the wheels but I’ve never run spacers… sooo… :shrug:
This is all my father wants to run on our truck and nothing will steer him away. I hate them along with the gunmetal/chrome lip everyone and their brother runs on the old chevy pickups.
I looked into the c6 wheel option for my 97’ c1500 as there was a set here locally. Seems like most people shy away from the idea because of spacers and adapters.
don’t judge me they were on the truck when I bought it. Ive been trying to find something better since I bought it…
I was talking more the torq thrust/boss style in gunmetal. I actually dig the wheels on your truck.
I don’t think Z06 wheels would look that bad :gotme:
I was mostly kidding btw don’t get a complex :slight_smile:
I really like the idea of Z06 wheels on this truck
Yeah I’m on board with this idea.
Are you drag racing or beating the crap out of this truck? If not then I don’t see why wheel spacers would be an issue.
Would you only be running spacers in the rear?
As you know I run eBay BMW reps on my nova.
Before the mini tub I had a solid inch - inch and a half of spacer in there. Only issue I’ve had was lugs coming loose when I didn’t wham them tight enough. I blame that on not seating in the wheel properly and me not torquing properly.
Rear I see being zero issue, front it’ll be a little tougher on the hubs. Running proper adapters and not just spacers will also work in your favor.
it would be both front and rear adapters and perhaps a small 1/4"spacer in the rear for proper fitment…hopefully without a mini tub
I have a set of these with no tires if you want to see how they look. Now that I think about it, you’re not in buffalo are you.
im not but how much you asking for them?
As long as they are a legit hub centric spacer, then they will be fine.
They aren’t for sale, just figured you could mock them up and make sure you like the look before buying a set. Doesn’t help since you aren’t local.
You could easily have hubs (rotors) and axles along with the rear drums redrilled. Parts for these are cheap AF. Straight up hubcentric spacers on ARP studs, done. Problem solved…
