All items for pickup or dropoff in local area - I am in Newmarket.
Z32 Front spindles and knuckles - originally gotten for the brake setup which I removed. Started removing spindles for dust shields but it was more trouble than it was worth. One spindle is knocked loose. - SOLD
S14 USDM Front Brakes with stainless lines and rotors, all pads and both rotors are about 50% Pads/rotors do not appear to be of a decent brand, lines look like SPL, but old…work fine though. - 40$ for everything
S14 Passenger vent assembly - nothing broken, just missing one of the inner upright directional tabs, and one of the horizontal ones is a slightly different color - FREE
S14 passenger handle/lock/window/switch - pcs broken as seen in pics (the usual areas), may be used for the switches if you need them. - FREE
Alpine V-12 MRV T757 - 2/1 channel amplifier ($400 or best offer)
Key Features
• Max Power (EIAJ) 225Wx2 (4ohm; Stereo) 750Wx1 (Bridged 4ohm;)
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 75Wx2 2ohm; Stereo (0.3% THD) 150x2 Bridged 4ohm; (0.3% THD) 300x1
• 14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 100Wx2 2ohm; Stereo (0.3% THD) 200x2 Bridged 4ohm; (0.3% THD) 400x1
• S/N Ratio 105dBA
• Frequency Response 10-50kHz
• 24dB LP/12dB HP Crossover (30-200Hz)
•1-Band Parametric EQ
(30-200Hz)
• Subsonic Filter (15Hz)
• Fan Cooled
• 4 Volt Input Capability
• Continuously Adjustable Crossovers
• DC Straight, STAR Topology & Duo-B Circuitry
• DC-DC/PWM MOSFET Power Supply
2/1 Channel Operation
Adjustable Crossover (HP/LP)
Auto High Temperature Protection
Auto Overcurrent Protection
Both sides Terminal Layout
Buffer Pre-Amp Output
Continuously Adjustable Gain Control
DC Straight Design
DC-DC PWM Power Supply
Direct Batt. Terminal
Discrete Pre-Amp Stage
Duo Feedback Circuit
Gold Plated Insert Power Terminals
Gold Plated Insert Speaker Terminals
Gold Plated RCA Input Connectors
High Damping Factor Circuit
Input Mode Selector Switch
Large-sized Fuse
Low Impedance Drive Capability
MOSFET Final Outputs
MOSFET Power Supply
MultiMode
Noise Elimination Coil
Phase Selector
STAR Circuitry
Solid Copper Bus Bars
Subsonic Filter
Top Mounted Multi Status Indicator with LED
Top Panel Adj. of Parame. EQ/Gain/Crossover
Alpine V-Power MRP T220 - 2/1 channel amplifier - specifications: ($60)
General
Product Type Amplifier
Recommended Use Car
Width 9.5 in
Depth 6.8 in
Height 2.4 in
Weight 4.2 lbs
Audio System
Digital Storage Media None
Audio system controls Gain
Amplifier signal-to-noise ratio 100.0 dB
Amplifier continuous power / channel qty 70 Watts x 2
Amplifier output 2-channel
Amplifier high level inputs Yes
Amplifier input signal voltage 0.2 - 4V
Crossover type 2-way active crossover
Crossover slope 18.0 dB/octave
Crossover low pass frequencies 80 Hz
Crossover high pass frequencies 80 Hz
Crossover bass boost frequency 50 Hz
Crossover bass boost gain 0 to +12dB
Amplifier Output Details 70.0 Watt - 4.0 Ohm - THD 0.3 % - 14.4V DC - 1.0 channel(s) , 140.0 Watt - 2.0 Ohm - THD 0.3 % - 14.4V DC - 2.0 channel(s) , 50.0 Watt - 4.0 Ohm - THD 0.08 % - 14.4V DC - 2.0 channel(s)
Additional features Gold plated connectors , Subsonic filter
Radio
Type None
CD System
CD system type None
TV Tuner
Type None
Connections
Connector Type 1.0 x Audio line-in ( Screw-type ) , 2.0 x Speakers output ( RCA phono x 2 ) , 2.0 x DC power input ( Screw-type ) , Speakers input
Miscellaneous
Antenna None
MD System
MD system type None
Cassette System
Cassette system type None
Remote Control
Remote control type None
Remote Control (2nd)
Remote control (2nd) type
