Phase II Heads/Cam and bolt-ons
Phase II
LS1/LS6 Heads/Cam swap + bolt-ons
So after you’ve swapped the coolest motor in the world, or perhaps you’ve bought a 4th gen Camaro/Firebird, maybe even a Corvette with a LS1 the best bang for your buck is doing a heads and cam swap on the motor.
With my first 98 LS1 having a broken rod I wanted to look into my newer 99 LS1 alittle closer, change out bearings and add alittle more fun. I wanted to keep it on a budget but make some good power so I called up Texas Speed and Performance, they set me up with their 233/239 cam on a 112lsa for alittle extra bump and their 5.3L heads with the stage 2.5 port job. While you have the motor opened up it’s a good idea to change out the oil pump, I went with their ported LS6 pump, and also an LS2 timing chain. And lastly I slapped on an SLP underdriven harmonic balancer. Here are the steps and pics as I went along.
First the stock 99’ stipped down
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls18.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls17.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls16.jpg
Next remove the rocker arms, pushrods and lifter, then you can take the head bolts out and remove the heads.
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls110.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls111.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls113.jpg
After this remove the oil pan, harmonic balancer, and front motor cover
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls19.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls1.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/99ls11.jpg
At this point I took the time to scrub and clean the whole external parts of the block. You can pull the oil pump & pickup off, then slide the cam out. Lube up the new cam and put that in. put the new oil pump on and the front cover.
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1081.jpg
And then the shiney new heads are good to bolt on, I used a set of ARP head bolts for added strength since I planned on using nitrous at some point.
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1085.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1086.jpg
Now here I cleaned up and painted the valve covers, as well as the LS6 intake the same color as my roll bar called Black Metal Flake. Definitely gave it a lot cooler appearance. And you can also install the new harmonic balancer. Simply toss it in the oven on 350* for about 45 min, it’ll go on the majority of the way then you need to get a longer crank bolt and you’ll be able to draw the balancer on the rest of the way.
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1088.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1090.jpg
Engine with the intake in place looking hawt
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1093.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1096.jpg
Motor Installed
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1098.jpg
http://img.photobucket.com/albums/v229/orangeiroc/LS1%20swap%20pix/IROCLS1099.jpg
Happy Modding…
And the first start-up after all of the mods…
http://img.photobucket.com/albums/v229/orangeiroc/th_FirstStartUp.jpg
u rule mike.
u gonna show the aftermath pics of your bearings :lol:
is it ok if i just blew my load in my pants…
i have a thing for the LSx series…
sexy!
NO snow, Old vid?
tup
vid is from this past summer when he did the swap.
:word: that vid is from like june…and i love how holly makes a cameo appearance :slight_smile:
why dose it sound like the exhaust it popin could just be bad audio from the cam
its called a big bump stick man lol V8 powa ftw
Love the sound of V8 crackle
i thought it was just the vid cam sounds cool nice work
nice trunk prop. sounds pretty sick though!!! :tup:
sounds dope…
what’s the car in the first pic?
his dads race car
good stuff
nice iroc:snky::shoot:
1967 Camaro, fully caged, back halved, front halved, drag car. Its one of 2 of my dads Camaros. My brother drives this one weekly at lancaster and a few races at NYIRP as well as Norwalk, Ohio.
Thanks for the compliments :wink:
http://www.dankollander.exposuremanager.com/p/092107_super_rod/09210723938
Nice!
