FOR SALE - SOLD
2000 SUBARU IMPREZA 2.5RS w/ ’04 WRX motor swap
Milage on chassis – 373K km
Milage on engine/ drivetraim – 140K km (approx)
Engine - 2004 EJ20 from a wrx, swap done by Lachute Performance. Very clean swap, I have found NOTHING hacked.
Tranny - 2004 RS roughly 120K-130K km, shifts like butter
Brakes - All serviced a few months ago, in perfect working order
Misc - I replaced both rear wheel bearings and have receipts to prove.
The good:
Mechanically Solid, engine runs perfect and pulls hard! Doesn’t burn a drop of oil and has had timing belt replaced already. Plus its got quite a few goodies:
-K&N cold air intake
-Perrin lightweight pulley
-Cobb V1 Access Port (theres a bunch of different tunes on it, currently running a cobb stage 2 map)
- catless uppipe coated and wraped (no sweaty valve cover
) - full 3” turbo back exhaust with hi-flo cat and cf muffler
- ACT stage 1 street clutch (rebuilt by Eurodrive 4 months ago)
-Group A front endlinks
-Perrin rear endlinks
-Perrin rear sway
-DMS adjustable coilovers
-5zigen 5ZR wheels w/ yokohama advan sport tires (one season left) specs: 17 x 7.5 +48 225/45/17
-kartboy shortshifter
-rear brembo drilled rotors w/ pbr metalmaster pads
The Bad:
Rusty, body needs rust repair and paint.
Needs rear ABS sensors for ABS to work (if you like abs… booooooo)
