SOLD SOLD SOLD
Well I know the title may shock you all but I am putting this out as a feeler for a reason. I have had my eye on a certain house for years and I received a call today that the owner is expecting to relocate in a few months and if I was interested I can do a private party sale before it even hit the market. I was not expecting this and assuming I will be able to purchase it in the near future I would need to generate the cash for the down payment. Sooo…
2004 STi WRB Fully built by Innovative
Roughly 112k on body and 2k on the brand new build
The body is mint and there is ZERO damage or rust
The Interior is clean as can be and has 40k on it as it was swapped out for the newer less worn interior
Engine
- Innovative stage 2 built block to custom specs and balanced (their secret sauce;) )
- Custom Cobb tune from Mike at Innovative Tuning for speed density
- Manley turbo tough I-rods
- Manley forged pistons
- ACL Bearings
- ARP Head Studs
- Factory nitrided crank
- 2008 11mm oil pump
- Killer B oil pickup
- Innovative stage 2 built heads (more secret sauce please)
- Manley valve spring with Titanium retainer kit
- Manley Intake valve kit
- Manley Performance Extreme Alloy Exhaust Valve Set
- Kelford 272 272 street performance cams
- LIC Motorsports adjustable idler pulley set
- Gates Timing Kit
- Crawford AOS
- Koyo Radiator Caps
- Koyo Radiator
- TGV deletes
- Ams Rotated 900x turbo kit
- Cast stainless steel Up-pipe
- Tial 44mm V-band wastegate
- AMS high flow cat
- Stainless steel 3” downpipe with integrated Stainless steel flex section
- Stainless oil feed lines
- Custom AMS stainless steel oil return line
- Black powder coated 4” non-MAF short ram intake with K&N air filter
- AMS spec Precision Turbo GT 6266 series dual ball bearing turbo with
ported compressor cover and Precision V-band turbine housing - Walbro
- DW 850 cc injectors
- Omni 4 Bar Sensor
- Grimmspeed EBCS
- Perrin EL Headers
- 3" Borla hush exhaust
- Perrin FMIC
- Perrin blow thru
- NGK One step colder plugs
- Gimmick turbo blanket
- Dimple Magnetic Oil Drain Plug
Interior
- ATI Pod with Defi gauges clock replacement
- Ati column pod wirh AEM Wideband and oil pressure
- Apexi turbo timer
- Led Conversion
- Converted all green lights to the STi Red ( hvac, etc)
- New speakers up front
- Alpine type R 10" 500 watt rms sub in the trunk
- Hard Wired the Valentine 1
- JDM Red Hazard Light Switch
Tranny/Driveline
- Kart boy short shifter
- Kart boy shifter bushings
- ACT Heavy Duty Street Clutch
- Goodridge Stainless clutch line
- Fresh fluids in tranny and diff
Exterior
- Wrb Wingless trunk
- JDM Tail light “conversion”
- Badgeless trunk
- Decepticon Front Badge
- Hella Horns
- Hollowed Passenger Fog Bezel
- Front Lip
- Perrin Front Plate Delete
Suspension/Brakes (the good stuff will be coming no worries)
- RCE Springs (from previous owner)
- Stock Strut Bars
- Stop-Tech Pads
A) The car’s kbb is :
Excellent $15,705
Very Good $15,205
Good $14,705
Fair $13,005
B) A few things just installed:
Python alarm w/2000 ft range remote start $500
Continental Extreme Winter Contact snows $600
C) All work done by Innovative
Here is a copy of my last page of the 5 page invoice:
The price is $21,935
I also have a few misc receipts for things like the Perrin FMIC that are around $4000
I do have receipts for everything. Here is a recap
*21,935 from the build that is a month old
*4,000 in other parts like Perrin FMIC, radio, sub, turbo blankets etc
*1,100 in new tires and alarm 2 weeks ago
*15,000 for in between value on kbb for good/very good
All this totals out to be $42,035
The Good
EVERYTHING
The car rides and drives like a dream and is the fastest car I have ever experienced
The Bad
NOTHING
I know that is not going to be feasible and I am looking for a quicker sale rather than sitting on this. So I am going to ask
$20000 HUGE bump for bottom line price drop!!!..bump for another big price drop
716-848-9969
That is over $16k off!! There will be no low ball or part outs of this what so ever. This is basically the price of the car and half the cost of an insane build. Please spread the word as I would like to move it fast to grab this home. Thank you
