1989 Master Cylinder same as 1992?
Does a 89 240sx Clutch Master Cylinder fit into a 92? Please help, I need info quick.
Looking at my FSM’s it looks the same from 1989 - 1998?
Philip?
The only diference is with ABS systems non ABS has 3 ports (3-way split ) two front and one rear.v On the ABS master cylender one of the front ports is pluged up and only uses two ports. The preportioning valve (built in) and bore are the same though.
pssst… CLUTCH master cylinder :lol:
I guess its different, we will leave it at that.
