1990 240sx HB With RB26DET new price
Make/Model: Nissan / 240sx
Asking Price: $ 16,500.00 Firm
Condition: Used
Mileage: 160,000KM on body 1000KM on engine
Contact Info: Send PM for contact details and to schedule a meet
Description:
This is not a joke, the car is for sale, and is in running condition.
Reason for selling: Changes in his life.
1990 240sx HB
Exterior:
- Color: color change peral
- 50MM over rear quarter pannels
- 20MM over front fenders
- D1 body kit
- Mitsubishi eclipse gas cover (real brushed aluminum not fake and not knockoff)
- Type X spoiler
- Type X tail lights
- Sunken in headlights with dual light assembly
- 18" axxies widetrack
- Bear fiberglass vented hood
Susspention:
- VLSD from a 91
- CP racing front STB
- CP racing pillow ball TC rods
- Custom Aluminum drive shaft
- D2 coilovers (rebuilt)
- 350z Brembro breaks
- Cross drilled and sloted rotors all round
- SS break lines
Engine:
- RB26DET (rebuilt)
- Converted to MAP sensor
- Wesco oversized pistons
- Machined block, blueprinted and shaved deck
- Stage 3 port and polish, w/ 5 angle valve job
- N1 Oil pump and machined crank(fixes the failing oil pump issue these motors have)
- Custom S13 RB mounts
- RB25DET tranny (5 speed)
- Act Stage 3 clutch six puck (sprung center)
- RB25DET slave cylinder
- Holsat T78 sized turbo (max boost of 32psi) polished
- Custom oil lines and break lines
- 4" Custom intercooler core with total piping length of 30cm
- Koyo Radiator
- Flexi-lite fans
- Aeromotive Fuel pump (supports up to 800hp on turbo cars)
- 10AN fuel lines from tank forward
- Sumped Gas tank with 10AN fittings
- 850CC MSD injecters
- HKS fuel rail
- Aeromotive FPS
- Tail 40mm external Waist gate
- Custom 4" engine back exhaust
- HKS SSQV BOV
- Intercooler spray kit
Electronics:
- Apexi Power FC D-jetro
- Power FC commander
- Apexi AVCR boost controller
- The car is wired for a decent sound system but no audio is included
Interior:
- Custom door pannels, window controlls removed, fiberglassed center section painted the same color as the car
- Customer fabricated dash with center channel for 5.1 surround sound and in dash screen (also the same color as the car)
- Tenzeo reclinable racing seats (red)
- Redone rear pannels (red)
- 4 point racing harnesses
- Custom center console with window controls
Specs:
- Octane: 94 from sunoco (car was dyno tuned for this)
- Puts down 434 RWHP at 12PSI
- Fully spooled by 4000RPM (redline of 8000, and was set to this to be reserved)
- Engine has about 1500km since rebuild, oil changed every 500km
The price is frim, There is alot more into this car then listed, car is currently saftied and e-tested cert only good for 20 days, serouse buyers only, No test drives, test ride can be arranged depending. PM is key, willing to trade. Dyno results and build pictures available at http://u2ndyno.com/forums/viewtopic.php?t=12.
