FS: 91 240sx built sr20det
selling my 1991 240sx. car is very clean and very well taken care of. however the engine was seized on the dyno last year after making around 340 hp. (oil pump may have failed). i will sell with the car as is or with a new built bottom end, running and tuned properly. over $25,000 invested in the car, i will take any resonable offers.
email me for any more info or for pictures of the car. must see to appreciate
splat26@hotmail.com
matt: 780-228-2738
here is a parts list.
Engine:
SR20DET Engine (Redtop)
87mm JE Forged Pistons; 8.5:1 Compression
JE Piston Rings
0.040" Overbore
Eagle H-Beam Connecting Rods
ARP Rod Bolts
Decked Block
Balanced Rotating Assembly
Polished Crank
Clevite Bearings (Rod, Mains, Thrust)(Clearance within Specs)
New OEM Oil Pump
New Intake and Exhaust Valves
New Valve Guides
New Valve Seats
Minor Valve grind
Cometic Metal Head Gasket
ARP Head Studs
HKS Step 2 Cam Shafts
Grex Rocker Arm Stoppers
Mushimoto radiator
Nismo thermostat
Splitfire coil packs
Bolt On’s:
Garret GT25R .86a/r Turbo
HKS Wastegate Actuator
SSA Equal Length Exhaust Manifol
Apexi N1 3” catback exhaust
Custom 3" Downpipe
SSA 3" o2 Extension
Greddy Style Big Capacity Oil Pan
Apexi Front Mount Intercooler
Custom Intercooler Piping with T-Bolt Clamps
TurboSmart SS Type III Blow off valve
Infiniti Q45 MAF (Air Flow Meter)
Topspeed Intake Manifold
Tomei Top Feed Fuel Rail
MSD 72lb/hr Injectors (Bench tested)
Custom Fuel lines
MR Fuel Pressure Regulator (Set at 49psi)
Walbro 255lph Fuel Pump
MR Pulley Set
ACT 6-puck Clutch
Toda Lightweight Flywheel
Short Shifter Kit
Electronics:
Apexi Power FC ECU w/ Commander
Blitz Dual SBC Boost Controller
Apexi Turbo Timer
Zeitronix Wideband o2 Sensor w/ Datalogging
Nova Alarm System
Exterior:
Custom Front Bumper
GP Sports Sideskirts
Vertex Rear Bumper
Buddy Club P1 Wheels (Front 17" x 7" +35)(Rear 17" x 8" +32)
new tires (Front: 215/40/17 Rear: 245/40/17)
Pivot Headlight Controller
Mercedes ML Sidemarkers
Interior:
Techniq Auto detachable Steering wheel
AutoMeter Guage pod
AutoMeter Boost Gauge
zeitronix zr-1 wideband 5 in 1 gauge
Panasonic Head Unit
custom trunk W/ battery mount
Suspension/brakes:
Tomei Circuit Stroke Stuts
Unknown Lowering Springs (very stiff spring rates)
Cusco Camber Plates
OBX Front and Rear strut tower bars
Energie Suspension Polyurethane Bushing Kit
Specialty Z Rear Sub Frame Spacers
Nissan 300ZX TT Brake upgrade
PBR Metal Master Brake pads
Stainless Steal Braided brake line conversion
MR C-Pillar Bar
MR Rear Lower Tie Bar
Moving this to the FS Thread
Any pics of this beast?
Car sounds very familiar…
Please read the forum rules!
oh yes it does… I see red
ya its red, and yes its aarons old car. ive got lots of pics of the car but i dont know how to post them on this f*ing site. if you really want some pics send me an email.
sorry, didn’t see a price
