Car currently is running 277whp @ 11psi.
380whp @ 14psi
11.6 @ 124mph
Car is silly fast! Throws you in the seat, all loose objects end in the backseat, tires scream for traction through 1st-2nd
rock solid ride, no funny noises/vibrations here!
reason for sale: Car is in perfect running condition… Just really want to get back into a 240sx.
1990 Acura Integra LS Turbo
Colour: White
320k
5 spd
Power Windows
Power Sunroof
Black Hood
93 Integra Front Bumper Conversion
JDM One Piece Headlights
Type R Front Lip
Engine:
1995 B18b1 Block 130k
- New Headgasket
- New Timing Belt
- New GSR Oil Pump
- New Tensioner
- New Water Pump
- New Oil Pan Gasket
1995 B18b1 Head
- Fully Ported by Gord Bush
- Crower Springs and Retainers
- Crower 404 Cams
- ARP Head Studs
- Ported Type R Throttle Body
- Prelude Fuel Pressure Regulator
- RC 550’s
- New Valve Cover Gaskets
- New Intake Manifold Gasket
- White Valve Cover
- New NGK Blue Spark Plug Wires
- New NGK #8 Plugs
Drivetrain:
- LS tranny
- Exedy 8.8lb Flywheel
- Stage 4 Clutch
- Custom Driveshafts
Turbo Setup
- Precision PT6776 S Turbo (.70 A/R Compressor, 0.82 A/R Exhaust)
- Full Stainless Braided Feed (-3) and Return (-10) Lines
- K&N Turbo Filter
- Blox Log Manifold
- TurboSmart 38mm Wastegate
- TurboSmart VeePort Blow Off Valve
- TurboSmart Single Stage Boost Controller
- 2.5" Stainless Charge Pipes
- 2.5" Aluminum Back Door Pipe
- Custom Backdoor Intercooler (28 x 10 x 3)
- 3" Stainless Downpipe
- Full 3" Galvanized Exhaust
- DNA 3" Muffler
- GM 3 Bar Map Sensor
- Walbro 255lph Pump
FAL Slim Fan
Del Sol VTEC Rad
New Alternator
New Gas Tank
Universal Spinners Catch Can
Suspension
- Tokico Blues w/ Generic Coilovers in Front
- Omni Full Coilovers in Rear
- Energy Suspension Front Sway Bar Bushings
- Energy Suspension Front Sway Bar Endlinks
- Energy Suspension Radius Rod Bushings
- KVR Slotted Front Rotors and Pads
- 16" Enkei Rims with New 205/45/16 Sumitomo HTR Z Tires
Interior
- Stock Seats
- Momo Race Red Steering Wheel
- Momo Black Leather w/ Red Stitch Shift Boot
- Momo Black Leather w/ Red Stitch E Brake Boot
- Custom 3 Gauge Pod on Center Console
- Autometer 2 1/16" Sport Comp Boost, A/F and EGT Gauges
- White Faced Gauges
- Alpine Type R Speakers
Located in Burlington.
Asking 4900$ OBO
no trades,:rolleyes: unless it’s an s14!
