Posting this for a friend:
1999 ACURA INTEGRA TURBO FOR SALE $4,000
I have a 1999 Acura Integra GSR, Forest Green in color. The car came with a blown motor and it was recently rebuilt with brand new parts.
There’s around 500 miles on the new motor and 160,000 on the body/chassis.
Motor:
-96 ls bottom end with new OEM color matched bearings and new OEM rings
-New timing belt, water pump, oil pump, and tensioner.
-New oil pan gasket, new coolant bypass seals, new head gasket.
-LS head that has been port and polished and gasket matched.
-valves properly adjusted, new arp head studs, titanium valve springs.
-New valve cover gasket and cam seals, upgraded cams with adjustable cam gears.
-330cc injectors with new injector seals, AEM high flow fuel rail with regulator.
=Victory x intake manifold with new manifold gasket, 70mm throttle body.
-Ram horn turbo exhaust manifold with external 8 PSI wastegate.
-T3/T4 turbo with front mount intercooler and blow off valve
-It does come with a boost controller but it’s not hooked up right now.
-Chipped ecu that has a street tune on it.
-GSR transmission with a stage 3 6 puck clutch and fedenza lightened flywheel.
-A pillar gauge pod with aem wide band o2, boost, and volt gauges
Suspension:
-Front and rear upper strut bars, front camber kit, new rear lower control arms, as well as coilovers all around
-17" wheels, rear slotted rotors and a front traction bar system
Other:
-HID headlights with Halo ring
-Hood pins
Any questions, feel free to call, his name is AJ 518-369-9749
