MESSED UP ON ORIGINAL PRICE… it is $3200/best offer. Will also sell car without 949 wheels for a lower price. Corbeau FX1 seat and harnesses also included.
[ATTACH=CONFIG]33448[/ATTACH]
[ATTACH=CONFIG]33449[/ATTACH]
Bought off Checko at the beginning of summer as an autocross projet. Car has ZERO and I mean ZERO rust. All bolts anti-seized. Very good condition. Brand new windshield,
GOOD/NEW:
-no rust/rot
-new head gasket
-head decked
-timing belt
-waterpump
-oil pump
-valve seals/lapped
-dizzy
-NGK [plug wires](http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=plug wires) & plugs
-new muffler
-brakes
-Si front seats
-Si front lip
on to the BAD:
- it burns a bit of oil.
-throwout bearing is noisy. clutch itself is good
Just added Koni SPSS Race adjustable Koni suspension, with Ground control coilovers with custom spring rates from Chris @ Redshift motorsports (the EF Susupension Guru) Also has 15x7.5 949 racing 6UL wheels (12 lbs each) , with 205 50 15 Dunlop Direzza Z2 tires.
Car has serious potential, currently running it in SCCA street touring class. Perfect car to be swapped, caged, etc. to become a terror. Great thing about the car is it is the STD version, so no sunroof, powersteering, AC etc. so it only weighs in at about 1940 lbs. I just dont have the time to run it as much as I want to, and it takes up my garage space. Only current issue witht he car is that it burns alittle oil, but its a honda and will run forever, just keep an eye on the oil. Or swap it! Looking to get $3200/best offer. You wont find a better EF out there.
