Ok,
I have been doing some research and cannot pin out what is happening with these two problems however I believe they could be related
When I bought the car the power door locks and the intermitent wipers worked just fine
after a year the wipers would not park properly so I replaced the amplifier and the motor from a scrap yard and it fixed the problem
a little bit after the door locks stopped working ( the car does not have a switch for the door locks, when you lock the drivers door it would lock the passenger, or when I pressed the lock button on the key fob it would lock)
A relay still clicks when you press the button and the lights flash but that is all ( alarm engages but doors do nothing )
maybe a week or two after this the intermitent wipers stopped working, they work on meduim speed and fast, and they do not wipe when you use the windshield washer sprayers ( sprays but doesnt wipe )
I believe this could be related to the Timing control unit but am not sure and have not inspected it
Does anyone have any suggestions
Thanks,
Jay
