Bump - The A/C in this thing is frigid!
Saw this beast Rollin down state st today. Looks good. Glws
Thanks man, it’s a fun rig for sure! Kinda makes me want to keep it because it’s fun to drive.
Spent yesterday out bombing around in this beast, it was a lot of fun! The A/C almost froze my feet off!
Bump for the evening.
And to answer a few lingering questions if you have them because of a lot of inquiries I’ve gotten:
[FONT=Helv][SIZE=2]Overall the truck is in very good shape for its age. I had actually purchased it with the intention of keeping it and putting a Cummins diesel into it because it was in such nice shape. With that being said I didn’t want to purchase a junk truck.
I did check over the truck pretty thoroughly when i had first purchased it this year and everything is in good shape. I’m hoping this will answer all of your questions and then some.
Below is a general list of what was checked over:
-Checked the floors/undercarriage and found no rot
-Checked leaf spring mounts
-Checked drivetrain mounts/crossmembers
-Checked engine/transmission/transfer case operation - All function 100%
-Checked frame and body mounts and found no rot
-Checked and replaced 1 wheel bearing assembly on passender side
-Diagnosed and repaired Air Conditioning system
-Checked Universal Joints
-Checked front axles and axle boots
-Checked Interior electrics and all function correctly
-Checked front brakes and repaired passenger front brake hose
-Checked all brake/fuel lines for wear/rot and all are in good shape
-Checked trailer wiring for functionality - Did not check trailer brake function
-Checked functionality of keyless entry/wipers/rear glass/electric door locks/power windows
-Checked and replaced rear interior door handles due to damage
A few items worth mentioning:
-The ABS light turns on after a moment of driving - I have not had time to scan the truck for the source of the code, but it is most likely a wheel speed sensor given the ABS light only turns on after moving.
-The drivers side header connection to the Y-Pipe needs to be repaired with a new flange/new bolts on the header - I may/can repair this before its sold because it’s easy enough.
-The passenger side door jamb switch that turns the light on is missing, but does not leave the light on in the cab.
-The radiator was replaced by the previous owner and it seems there is a 160 degree thermostat in the truck, but it doesn’t affect the heat (I bought this in March).
-There are stainless headers on the truck
-There is a Banks Ram Air intake on the truck
-The original owners manual and window sticker are present
-The 6" lift kit installation instructions are also present - The kit is a Skyjacker I believe
-There are anti-Sway/helper springs installed in the rear suspension
-There is a class IV receiver installed and it is in great shape
-There are aftermarket headlamps and turn signals installed - Both have black housing and work fine
[/SIZE][/FONT]
Wow, no takers yet. I might put a plow on this pig for the winter then, lol!
Bump
Bump
Bump!
Sale Pending.
Just joking, buyer bailed. Still For sale!
Bump. Just fixed the exhaust flange because it was pissing me off and sealed up the leak at the oil cooler because that was pissing me off too. Somebody buy this thing before I just do the damn Cummins conversion and my wife leaves me!
SOLD SOLD SOLD
