I want to build something to rev-out and make big power, and am going with either the 2.0 or the 2.1. The 2.0 is tried and true, but I’m starting to lean more towards the 2.1 as it has that little extra displacement, plus another 2.5k of powerband.
If that is your goal then in my opinion you will be just fine with the 2.0. Picking the right turbo, cams, and tuning will put you right there. Honestly, you probably can do it without a 3052 if your other supporting parts are just right (but the 3052 will give you a bigger range if you ever decide to change your mind and go for a bit more power). I think it would be plausible to hit that number with one of the new EVOIII series turbos for a lot less money than the 3052 setup. I can think of 3 well known people in the DSM community that are hitting 350 with FPBig28s. So a big turbo is not necessary.
I dunno, I’m still waiting to see someone prove that the 2.1 can outrev the 2.0.
I understand the argument made for the 2.1 config: changing the rod length/ratio changes the breathing characteristics of the engine, and longer rods are “proven” to create greater high RPM power, and whatever the optimal angle for this thing is, it’s supposedly good. But can you justify the cost? I think you can get the same results with the 2.0 if you play the cards right. You could spend that money elsewhere. :shrug:
On the other hand the thought of a “High rev” 4G63 is sexy.
My FP3052 will spool around 3200 - 3500 @ 22psi… T28 can suck it…
EDIT - T28 is pretty good for < 20lbs of boost and 300whp at most. Anything more and it turns into a hairdryer and the turbo bearings won’t last that long because you will be running it at 20+ psi. You want easy 350whp, you want something 50trim size (2.123/3.0 compressor), standard bearing.
If you’re going for a DD w/ 350whp then I would say go with a 2.4L. I have one in my 1g and I noticed a huge difference over the stock 2.0. With a small turbo like the EvoIII you’d have full boost well below 3k, and even a 50trim would be spooled by 3k if setup right. A 2.4L and a standard bearing 50trim, for any turbo that size, would put you right where you want for a 350whp DD.
2.3 if you dont want too much down time and want to use your same block, or 2.4 for the street. Torque is what gets you moving, torque wins races, horsepower sells cars.
Just for reference, there has been an ongoing Turbo comparison done on a single platform by Slowboy comparing various turbos. Here are the results for the EVO III
I don’t care what anyone says about high boost on the MHI EvoIII, anything about say 23+ lbs of boost is going to wear out prematurely. That turbo was never designed to run at those PR’s…
