2015 Ford F-150 Aluminum body
This should be interesting. It is funny how some are concerned that aluminum is too weak. I just paid huge money to have the rust remove from my truck, I can’t wait to see aluminum used. :slight_smile:
700 lbs is nothing to sneeze at
No rust for the cab, box & tailgate
This… Anyone living in a salt filled area should love this idea.
This isn’t the first time Ford has used aluminum body panels…the hoods on rangers, explorers, and expeditions in the late 90’s early 00’s were aluminum…and while aluminum doesn’t “rust” it certainly oxidizes/bubbles and sheds paint the same way steel does…hopefully they’ve found a better paint-adhesion process than previously used…
I’d be much more impressed to hear them offering the 5cyl diesel that’s available in the Transit in an f-150…
Apparently Aluminum can’t drive thru lava, looks like I won’t be buying a Ford.
A few more photos and other details.
This. You might not get rot holes like an all steel vehicle but salt and moisture will still make it corrode and bubble comparable to steel, soo it’s not perfect solution. Plus it might have problems with galvanic action anywhere it’s bolted to steel etc…
this is why all older land rovers look so nice even 40 years later! <3 aluminum bodies and rotted frames
Meh, I’ll take pitted aluminum over rotted steel any day.
I wouldn’t say it rusts the same way as steel. Yes it gets “white rust” but it is more resistant than steel. Leave a piece of steel outside and leave a piece of aluminum outside…
It’s about time. Now if they would paint the frames before selling the truck. Like actual paint. That doesn’t rust before you get it home.
Aluminum is a good business to be in: http://www.reuters.com/article/2014/01/11/autoshow-aluminum-idUSL2N0KK11Q20140111
they say aluminum demand will multiply 5x in the next 10+ years driven largely by US automakers trying to meet EPA standards by reducing weight.
this is just the start.
I was going to mention that aluminum pricing will greatly increase and it will kill my business. Maybe if F150s are made of aluminum my customers will finally understand a price increase.
Very stoked for this truck, might be on my list late this year. Kept it fairly true to the Atlas concept as well.
This
Bump up the thread
Strip the body paint a and polish that bitch.
