2g DSM/7 Bolt 4g63 Parts
Im copying this from rochdsm hoping maybe some of you have some of these parts just hanging around.
Im trying to get a couple of my cars running, and before i buy all new parts or order stuff in, i figure id see if anyone has this stuff they want to get rid of. heres what im lookin for:
ALL ENGINE PARTS ARE FOR A 7 BOLT
Main and Rod Bearings, block is a 98-99 with the Thrust Washer
Piston rings for OEM bore + OEM Pistons
Gaskets (Head gasket, intake manifold, throttle body, front case, exhaust manifold, etc, etc)
Oil Pump gears and/or Front case
Balance Shaft Elimination Kit
16G Install kit (oil + water lines)
J-Pipe for FMIC
Rear Main Seal
EvoIII Manifold or any manifold better then the stock 2g
EvoIII O2 Housing or any other better then stock housing
Heater Core
either shoot me a pm, post here, or send me a txt to 7163435166
thanks a lot guys and let me know what you got
bump…really need an oil pump/front case!
