5 bolt conversion
the car is an s14. when doing a 5 bolt hub conversion can you use 5 hole rotors or do you have to re drill the 4 hole rotors. also when you press out the old rear hub does it usualy wreck the bearing (pull the iner race out) i can get a 5 bolt rear hub assembly with bearing and housing for an s14 Le
will this bolt on to an SE. what do i do for front.
If you do a little bit of searching you will find all the answers you need.
http://www.az240sx.org/faq.html
Scroll down to 5lug conversion
FYI, rear rotors are same throught all 240sx models (S13 and S14)
