Here’s what I did. I wouldn’t bother going with the 300zx uprights and all
that junk just for a little weight savings. Not wroth it, especially for the
rear considering you will most likely need to replace your calipers with
300zx as well as your e-brake assembly I believe.
Front:
S14 spindle
S14 ball joints (or S14 control arms)
Sleeves for bolts used by struts/coilovers (see below).
Rear:
300zx N/A hub or S14 hub
Both:
5 lug rotors and wheels
Labour:
You will need a shop to help you press out the hub for the rear as well
as the ball joint for the front.
If you are going to use sleeves, you will need a shop to make them for
you. The specs on the sleeves are below. Or you can drill your
strut/coilovers. The S14 spindle uses thicker 14mm bolts I believe so
thats’s why you need the sleeves.
The sleeves are: 0.545" O.D., 0.469" I.D. and 30mm long.
