SOLD
91 Acura Integra LS
211,350 miles on chasis
100,xxx miles on engine/trans
$1,200 OBO
Highlights:
New Snow Tires (195/75/14 Firestone Winterforce)
5spd Manual trans
Cruise Control
Air Conditioning
Power Steering
Power Windows
Power Moonroof
Power Seatbelts
OEM CD player
The Good: :tup:
Replaced engine/trans. LOTS of maintenance done. New snow tires. Reliable. Great gas mileage 30+. Doesn’t leak fluids or burn oil. Compression test 180+psi on all cylinders. Gnarly monster truck tires with no wheel gap!
The Bad: :tdown:
Rusted to shit. Paint is faded where it’s not rusted. The moonroof works but the tracks are full of rust. Hatch keylock doesn’t work but trunk latch in cabin works. Dent in hatch. Antenna doesn’t retract but works. Ugly.
Maintenance performed: :tspry:
Replaced engine and transmission from DA9 with less miles
New throw out bearing
Set Valve lash
New Head gasket
New Timing Belt
New Waterpump
New Thermostat
New Radiator
New Battery
New Cap/Rotor/Igniter
New Plug wires (OEM) & Spark Plugs (NGK)
New Fuel Filter
Replaced Fuel Tank
Replaced rusted Fuel lines and Power Steering lines
A/C Compressor
A/C Drier/Evap
A/C Condensor
A/C Fan
A/C R134a Recharged properly
New Exhaust complete with cat (quiet)
Remanufactured Axles (pass, driver and intermediate)
New Tie Rods (pass and driver)
Remanufactured Rear Brake Calipers
Replaced Front Brake Calipers from 95 Integra GSR
New Rotors all around
New Brake pads all around
New Air filter
Replaced hatch shocks
Replaced front and rear motor mounts (OEM)
New windshield wipers (all 3)
All lightbulbs work
Alignment
Upgrades:
Silverstar hi/low headlight bulbs (white) and aimed correctly
Poly shifter bushings
GM Synchromesh Transmission fluid
ATE Super Blue brake fluid
