have a 93 si hatch i just did a bunch of bodywork and repainting it this weekend, i have about ~$1500 to put into a motor swap(motor has 240k on it)
now i do not have a specific goal in mind, i do not really want to go all out or have future plans for forced induction. I just want to keep it reliable and a lower mile motor with hopefully a few more ponies.
now swaps in mind:
LS
B series
now im not 100% what i need to accomplish my swap. Seems like i need an motor, ecu, wiring, tranny, axles, motormounts, shift linkage to do either of these swaps.
I have no sourced a motor yet either, so im basically asking for some help from some locals on this. Finding a COMPLETE motor swap. and maybe a little help but i think impretty good on the mechanic end of it.
hybridynamics 724-925-2660
i have an older ls swap it’s a b18a complete, but it’s obd0 and cable tranny. pm if interested…
i know its not what you said you are lookin for, but if you are interested, i’ll sell it to you cheep. it has a lot of extra parts
d16z6 swap, NO WIRING HARNESS!!! swap comes with del sol linkage, motor mounts, msd modified cap, original dist cap with internal coil, aem pullies, Taylor 8.5mm wires, zex plugs, chakera header, catco high flow cat, axles, rotors, calipers, always ran castrol syntec full synthetic with k&n oil and air filters. no problems with motor when it was pulled,Transmission is a USDM p20 Hydraulic non LSD. tranny has the usual third gear grind. newer centerforce dual friction clutch, throwout bearing, pilot bearing, new oem flywheel, synthetic tranny oil, all done about 5000 miles ago, engine and tranny have 136,xxx miles on them.
make me an offer if interested
sorry, not tryin to jack the thred and make it a classified…
I’m just Saying maybe a K.
