95 s14 Power Window Amp
looking for a power window amp, cant find any around me in part stores, 95 s14. text me at 647 637 953six thanks
S13 ones work too
most of the time you can just fix up the one you already have. un-bolt the box off your door, take the black cover off and pull out the circuit board. stick your face right up to it and check if you got any broken connections. you’ll prob spot one, so just grab your soldering iron and hook it back up. try that first
