Originally I thought it was just the drivers side window switch but it turned out it’s not. I’m thinking it’s possibly the power window amplifier (basically it’s the black box mounted on the door). Windows go down with no problem but it doesn’t go up most of the time… I’m thinking it’s the power window amp. The one I need to replace is the on the JDM driver’s door.
Dude I had that problem 2 weeks ago. I got one out of pick and pull for $6.25. Just check out the wreckers.
Darek
your talking about the relay? if you get it from the wreckers the auto up will not work, the auto down will…pm jdms13rhd he has some kicking around i belive/…
