96-98 obd2 ex or hx wire harness for motor
i need this wire harness asap please if anyone has it and willing to sell please let me know
hx is different i believe, esp since it has a “wide” band oem sensor and the ex doesnt
just use your dx and buy a vtec harness. do i need to go over and do it for you?
dx needs a couple changes for the iacv but its fairly easy
If I wanted to keep my dx wire harness what is it that I have to do I jus don’t want 2 chop my harness and I don’t got money all like that to be buying whatever. Its called for the vtec and knock sensor actually time to wait for the part.I need this car to turn on already
you can use the dx harness easily
http://www.ff-squad.com/technet/
use the writeups to convert your 3 wire iacv into a 2 wire (will just need the plug which isnt a problem to get)
i wouldnt worry about the knock sensor, to be honest they are junk with b series motors
vtec is really really easy to wire in
will you be using obd1 or 2 ecu?
I’m using a odb2 ecu and motor…I got it to turn on but no sooner I turn it on it turns off…I start tapping the gas it. Turns off.I replaced the gas pump and gas filter and checked the lines does anyone know what the problem can be?
