I just took this car in on trade. I just want to see if anyone wants it like this week, or else I am going to register it and put it on the road to drive for a while. It is a pretty built SOHC, compared to my original “batmobile” that made 156/148 on Innovatives dyno back in 2005, this car should run mid to low 14’s @ ~ 95 mph, and it gets 35+ mpg. The catch, it’s hideous. It doesn’t have any rust, but it has a home-brew paint job, so if you care about looks, it will need paint. It has upwards of around 6k in mods, and low miles.
I will get pictures and a full mod list up in the next day or so, but the obvoius are it is a 1997 2 door neon, originally purple, now this flat army green color. SOHC built engine, 5 speed trans with the 4.12 gears in it, and a limited slip. It has less than 65,000 original miles, and has no problems. Leaks no fluids, doesn’t smoke or have any problems, just an ugly paint job.
The mods are pretty extensive. Ed Peters ported SOHC head, Crane 12 cam, INDY intake manifold, iceman intake, longtube header, MSD ignition, HID headlights, phantom grip LSD, 4.12 gears, booger shifter bushings, Koni struts, Mopar High Rate springs, Neon R/T wheels, the list goes on and on.
It has no a/c, no ps, and a lot of weight redux from things like the trunk bracing, etc… It has the Mopar Performance PCM, so it revs to 7500 rpm (or is it 7800, i don’t remember), and passes inspection without a problem. Good for a quickly little daily driver, WONDERFUL for autox, or whatever.
I put my MOMO start seats in it, and those will stay in it if the buyer wants.
Again, I will be registering this if no one wants it, I am just throwing it out there before I have to wait 2 months for the title.
