I decided to keep whatever does not sell right away.
I consider this a project car and it will need some small work to be finished… or part it, i dont care i just dont want to do that yet.
Only contact me if truly interested… if not dont bother
$1200 firm
2g sypder, white, needs body work/paint (pass door and pass fender mainly) Fender is off right now because I was going to look for a replacement if kept.
All newer front suspension (lat arms, control arm, dog bones, etc)
newer axles (both sides)
Full tan leather interior in good condition, I cleaned them up a bit
Ripped the engine down and rebuilt, was going to turbo but have not got that far.
What I can remember at this minute:
Car currently runs and drives
Engine:
New 4g63 pistons in the 43 block
new headgasket
new timing belt / tensioner/ etc
new VSS in head
New clutch/ throwout bearing/ PP
machined flywheel to proper step
new clutch master cylinder
new slave cylinder
new pivot ball/shim (in tranny for shift fork)
oil pan is tapped for turbo drain
new starter
new battery
used TB and ISC motor
new engine mounts
new seals / gaskets etc
Exhaust is holy as ever. The car was running perfect until when i had the tranny out and the starter fell on the o2 sensor, now i have a CEL for it, but i have another o2 sensor
Car will come with turbo manifold and o2 housing (with sensor)
you can text me @ 315 569 3765, just mention spyder.
---------- Post added at 07:58 PM ---------- Previous post was at 07:40 PM ----------
of yea, front strut tower are solid no typical rot as found in similar models
